Re: Danny's been workin'
New article: 406.4(G)(1) - Receptacle outlets shall be installed with the ground pin up to prevent the fall of metallic and conductive objects from falling onto the energized contact blades from a poorly installed attachment plug. Where protected by an insulated barrier, the receptacle shall be installed either way. 406.4(G)(2) - Receptacle outlets shall be installed with ground pin down in an area where the flooring is bouncy as to allow a conductive or metallic object that has fallen bounce up and contact the energixed blades of a poorly installed attachment plug. Exception - floors with a listing of less than 13" bounctivity do not require ground pins down.
