Hi all,
I'm looking for some low-cost options to get automated power usage data for a single panelboard. The panel in question is rated 400A, three-phase, 120/208V, and serves a variety of building loads (part warehouse, part office in this case). Since this panel currently lacks a dedicated meter, I've been looking into both clamp-on and split-core CTs, and it seems the split-cores tend to be quite a bit cheaper.
For the data acquisition, we'd ideally like to receive reports either via e-mail or through a designated FTP upload location. We do not need advanced measurements, only kWh readings at designated intervals. Also, this is the only panel we are monitoring at this location, so the equipment does not need to be expandable to multiple metering locations.
I've been looking into a combination of these two items by Veris:
H8050 split-core CT (400A)
H8803 AcquiLite (Data Acquisition)
The manufacturer told me that the AcquiLite outputs CSV files for data and has an IP address, so you can log into it to extract data or configure it from a remote location. So it would seem nothing further is required except for an ethernet cable and Excel.
Has anyone had an experience with this system, or a similar one? If so, would any other equipment be required to achieve the result we're looking for? Also, are there any specific products you would recommend? I'm kind of new to data acquisition myself, so any advice would be greatly appreciated.
Thanks.
Thanks.
