Maybe. Take a look at 725.133(I).Is it legal to run a Cat 6 data cable for a security camera in a light pole with power wiring for the light?
You can run the data cable in LT flex, which is inside the pole
Yes, but I would not bundle them together or run them through the same hole in a stud.Ask yourself this. Can you run Cat 6 data cable in the same wall cavity in a house with power wires??
It does look like there is an exception for when the Class 2 or Class 3 cables are all in a non-metallic sheathed cable. I would say a CAT 6 cable would qualify.
Is the interior of the lamp post a raceway? If it contains individual power wires rather than a cable assembly, you might have an argument about that.
Or is it just the inside of utilization equipment and the NEC wiring system stopped at the base of the pole?
I could be wrong, but isn't Non-metallic sheathed low-voltage power cable type NM-B? Thus you would need to make sure it is rated as NM-B?
If Cat 6 cable automatically made the exception list then there would be almost no reason to put in 725.136(A) as everyone would just use Cat 5 or Cat 6 18AWG conductors.
