dave_asdf
- tampa florida
I work for a data center and I am currently developing a grounding standard. The question I have is about connecting the grounding system to building steel. My design only connects to building steel at one point, the MGB. The MGB also connects to the utility power neutral at the multigrounded neutral. Power is fed to the equipment on the data center floor through a UPS and a few PDU's. Each PDU has a 4 wire 480/208-120 D/Y transformer. My question is, should the secondary of the transformers be grounded to building steel or to the MGB? We also have ground bars located around the center, which are usually used for rack grounds, that connect to the MGB would this be a better place to connect? Since we have a few transformers in the center i was concerned about unbalanced loads on each phase causing a grounding loop if all transformer secondaries were grounded to building steel and the input neutral. Please advise, Thanks.
