Hobgoblin66
New member
- Southfield, MI
We have a project where ground conductors are being run from various data center ground bars to a central location for grounding reference. These grounds are not meant for fault current, only reference points. The electrician that installed these ground cables ran them through ferrous sleeves without bonding at either end. Is this a code issue? I don't believe that 250.64 applies as this is not used for fault current. Please correct me if I'm wrong.
