Dranetz make a range but you might want to hire rather than buy.Does anyone know of a good data logger I can purchase at a reasonable price. I will be measuring 3 phase voltage and current. Will also need to be able to pull the data and be able to see min, max, and rms. Let me know what everyone is using. Thanks!
I have been hiring an electrical contractor to take readings for me and we have used them several times, probably more than $2,000 this yr just for getting data. Might be more cost effective for me to have my own and take as many readings as I want, especially at $50 per day for data.
What you are paying for is not just the guys time
and the cost and up keep of the equipment. The meters are expensive enough then there are CT's, and repairs of the equipment.
I suppose it might depend on what data you want to collect, how you want to use it, and how often you want to or need to collect it.I have been hiring an electrical contractor to take readings for me and we have used them several times, probably more than $2,000 this yr just for getting data. Might be more cost effective for me to have my own and take as many readings as I want, especially at $50 per day for data.
At times, I'm the guy on the other side of the fence - I get contracted in to look at supply quality problems. It's not work I seek - it finds me.
For basic problems I use a digital scope with a storage medium - old hat but it works. For anything that needs 24 hour monitoring, I connect a laptop set up to trigger it and do a download every 30 minutes.
Analysis is done later and that's the time consuming part.
The rate for doing the job rarely reflects that aspect.
I continue to do it more for learning than earning.
I do.Not that it matters to me BUT, I see you are an engineer, often engineering firms hire me to make the connections set up the equipment (which I own).
Do you do all your own field work? installation and investigation?
For the record, I'm also a time served electrician.Not that it matters to me BUT, I see you are an engineer,
