Daylight Saving Time
barclayd
Colorado
Don't forget that Daylight Saving Time ends at 2:00am, Sunday, November 4.
Here's a little "ditty" I use to remember which way to set your clock or watch.
" SPRING UP & FALL OVER "
db
My RCA VCR/DVD player fell back last weekend but any changes in time, date or DST ON/OFF revert back everytime the unit is powered OFF/ON again!! Go figure....
Very odd not being able to set variable parameters! Wonder if it allows me to change the minutes? Now that would really be odd if it allowed that.
I don't know the brand but my brother-in-law said that his PDA did/does the exact same thing too.
It's all due to our Fine President pushing the change to when DST starts/ends. It's been almost as much work patching/adjusting all the computers as the y2k nonsense was. I wonder how many working hours have been spent resetting clocks on systems that don't (or can't) know about the change in the time change.
Not that I have a strong opinion about it...
I just wish they'd leave my clocks the h--l alone. They claim I'm saving time, but I spend hours every fall and spring locating all my clocks and changing them. And the 'daylight' angle??? Who are they trying to kid? Any idiot knows the sun is above the horizon only so long every day, and no amount of tinkering with our clocks is going to change that fact. I say split the difference between the two, and leave it at that.
time
time
More importantly...time to change smoke detector batteries
My DVD burner jumped the gun as well, and I ended up taping Dancing With The Stars (not amused :mad:) Yours is probably like mine, in that it sets it's clock from PBS.
"Computers don't make errors. What they do, they do on purpose" ~Dale Gribble
The 'saving' part is a myth. If they can get away with skewing the dates, they should also be able to change the name to Daylight Shifting Time.
I really couldn't give two shakes because my schedule is screwed up as it is. I don't relish having to check 100 clocks though.
Screw it all, I'm switching to UTC. See you at 2200 Zulu...
Okay...how about we leave Bush out of this one? Daylight savings time was implemented in 1916, for God's sake. Even Benjamin Franklin thought it was a good idea, though my personal opinion is it's a big load of &%*#@.
If he's not part of the solution, he's part of the problem, no? :grin:
It probably helped save coal durring the war, but I believe there is little evidence to support DST helps cut electricity useage overall. Consumption is reduced in the PM obviously; however the useage in the morning most nearly cancels it out. Here's the kicker, the sharper peak demand in the AM increases energy costs.
I can go running after work, in the light, for a few more weeks though.
If you are not part of the solution, then you might just be the boiling chip.
Seriously, there are loads of political forces pushing on both sides of the daylight savings time issue. Hell even the candy industry cares; they wanted the change to 'standard time' _after_ Halloween so that more young kids would have time to 'trick or treat' after school and before dark. We may all have feeling for or against our current President, but discussion of such simply causes rancor and distracts from discussion of electrical matters. I've watched good BBSs fall apart on such side discussions.
'Clock time' is related but does not match 'sun time'. We don't set our clocks each day to read noon when the sun is at its highest point in the sky, we set our clocks to a calculated average noon, and we don't set our clocks to average noon at our particular location, but to a standardized location in our 'time zone'. Once you give up local noon to accept 'time zones' and 'mean time' and the like, the setting of your clock becomes a political decision, trying to get lots of people to agree to the same standard.
-Jon
I'm glad I'm not the only one who thinks it's stupid. I'd say just leave it summer time year round, what would it matter?
That said, we obviously need to leave politics out of the discussion as much as possible, as others have pointed out.
