As above, large circuit breakers normally require a battery to function, unlike the small MCBs used residentialy which are self contained.
The battery may also supply other control, monitoring, or warning equipment.
If a standby diesel generator is installed then this normally has a battery to start the engine, seperate from the switchgear battery.
The engine starting battery may also power controls and instruments on the generating set.
In some places large backup batteries are installed not for switchgear operation or engine starting, but to actually power critcial loads in the event of failure of the utility supply.
In a few cases the load might use DC power direct from the battery, but it is more usuall to use an inverter to produce line voltage AC.
