BretHeilig
- Brooklyn NY
Hi,
I've always been told that when running a solar DC output circuit (typically ~7A @ ~400V), if any conductor passes through a metallic conduit, that another conductor on the same circuit with current flowing the opposite direction must also be in the same conduit (ex - the positive and the negative); that if this is not done, there will be undesirable induction on the conduit.
I know induction can only occur when there is a change in current flow. On most inverters, this happens on a programmed basis, and will happen about every 15 minutes, and the change is usually very small (< 2%) though it can sometimes be significant (for example if a cloud passes overhead). The direction of current flow never changes (as it does in AC).
The problem is, this requirement can be a serious pain sometimes, and I find myself questioning whether it is a real issue, or just superstition. Does anyone have any insight?
