Good afternoon.
I would like to replace a really old contactor for a 10hp, 230 VDC motor. It comes from early XXth century. It starts and accelerates the motor in 4 stages (increments) every 5 seconds (more or less) and then keeps it running till a water tower tank is full.
The contactor is a part of a setup to provide water to a water tank on top of a high-rise building.
It's coil is 230 VDC. It has to start and run as long as it receives voltage.
Is there a replacement unit on a market or would I have to build it from parts?
Would it be destructive for the motor if I didn't start it in 4 stages (increments) but used a simple 2 pole contactor? Is there a contactor with a DC coil?
Whats the science behind starting a DC motor like this?
I prepared a dropbox folder with a couple of pics and a short video.
https://www.dropbox.com/sh/cghqzf01ah0pmkd/AABWIhQcc3GPWbjmemgGdJREa?dl=0
Actual replacement part(s) would be very appreciated.
Thank you.
Thank you.
