drbond24
- Barboursville, West Virginia
I have a string of related questions based on a DC motor test I ran a couple of days ago. Fortunately for me, the test procedure makes performing the test fairly easy even though I'm not 100% sure of what I'm doing.
The main concern in the test is the oil pressure, not the electrical info on the motor, but I'm still supposed to write all of this down. Now I'm trying to figure out the results I got. Here we go:
1. My test procedure says to measure the 'shunt coil current,' the motor elementary diagram for the motor shows a 'shunt field,' and the motor nameplate has a rating for the 'field current.' Are these all the same thing? I've got college notes and a textbook that I can look up stuff on a 'shunt DC motor,' but I want to make sure I have my terminology straight.
2. If the answer to #1 is a yes, then what would make the field current way too big? The rating on the motor nameplate is 1.2 A and I measured 15.1 A.
3. If the answer to #1 is a no, can you explain the difference(s) to me?
I tried to attach the elementary drawing I'm looking at. Hopefully that worked so we're on the same page. I had a current clamp around the conductor labeled F1 on the left side of the page, which is where I got the 15.1 A from. The motor is a 10 HP DC.
If you need more information or have questions, fire away and I'll do the best I can. I'm obviously rusty on my DC motors. Haven't messed with them since my Electromagnetic Devices college course.
Thanks!
Thanks!
