Hi, I need the winding resistance on this motor for calculations related to a turbine development:
24 volt 0.5 amp at 375 RPMs DC Indiana general motor
I assume that the steady state resistance is 48ohms and includes the back EMF.
But the startup resistance is the actual winding resistance i believe. so i assume the startup current will be higher than 1/2Amp and Resistance is really smaller. is it likely half? a third? 10% less?
Can i measure this or estimate it somehow. It does not have to be perfect...and an estimate would be great!
Motivation: the output of the generator for the turbine is based on the resistance in the windings and affects my blade design.
thanks.
thanks.
