electro7
- Northern CA, US
- Electrician, Solar and Electrical Contractor
Hi,
I am calculating wire size for a 220kw ground mount system that would be located around 1900ft away from the point of interconnection. I am looking at a module that has 8.66 amps at mmp with 14 mods per string, which would be around 434 volts. What size wire would I need to keep the voltage drop under 2%?
Also, does anybody know if you can do 1000 volt systems for commercial? I thought I heard it passed in the 2014 code, but was also wondering if it was a jurisdictional thing?
I was thinking to have the inverter near the point of connection and run the DC the 1900ft, thinking it would help with voltage drop. We are still in the design stage of this though, so any thoughts on what would be most cost effective would help out a lot.
Thanks!
Thanks!
