DC voltage minimum spacings
berzerk
Hello, my question is...
Is there a minimum spacings (clearance) chart for DC voltages? I know there is for AC voltage in the NEC book, but looking for one for DC voltage. I have a 1200VDC application and need to know the clearance i need to ground.
I see nothing that designates AC from DC -- are your referring to earth or a grounded conductor
Voltage, Nominal. A nominal value assigned to a circuit or system for the purpose of conveniently designating its voltage class (e.g., 120/240 volts, 480Y/277 volts, 600 volts).
225.60 Clearances over Roadways, Walkways, Rail, Water, and Open Land
225.61 Clearances over Buildings and Other Structures
Services Exceeding 1000 Volts, Nominal
I'm talking about what the clearance i'd need to a steel bracket (ground). For say, 600VAC through air it is 1", but what is it for 1200VDC?
