Today I got a call from a paper mill that has a DC drive system with about 15 ndividual DC drives all on the same (paper making) machine. For those of you who have had experience on such systems, you will know that it's quite an exacting application. Typically, speed holding has to be within 0.1% otherwise the paper breaks and production stops. The motors are 600Vdc and are mostly from 100kW to 300kW. The machine, as a whole, usually runs at maximum speed or close to it so all the motors run at close to maximum speed. That's the background.
So to the reported problem.
One motor was running at an armature voltage 150Vdc instead of the usual 550V - 600V.
The machine was in production so this particular motor had to be running at the correct speed. I asked the electrical guy if he had checked the motor field voltage. He had. It was about 50% higher than normal.
Any thoughts on what the problem might be?
