mbrooke
Batteries Included
- United States
- Technician
If a tree leans over and rests into 15kv tree wire is it necessary to de-energize the 12.47kv primary? This just happened next to my house. I still have power.
I find it had to believe those lines would still be powered. Seems like a tree would be enough to take out a re-closer.
15kv tree wire
I’ve seen this happen 20+ years back on a 11kV OH line. The tree caught fire but the supply breaker didn’t trip. I had to phone the DNO (PoCo) to get the supply shut down.
I did get some benefit from it, two cows were killed and I got some good pieces of beef from the farmer.
Stray voltage is horrendous with 4 legs.
Yep. No insulating boots.........![]()
If only cows could fly as chickens do.![]()
Ahem:
Which would be this :thumbsup:
https://www.marmonutility.com/Portals/0/PDFs/Covered_Conductors-Tree_Wire_Systems.pdf
The insulation on the tree wire is apparently in good enough shape to withstand the applied voltage. But I would not under any circumstances try to clear the tree without first de-energizing the line. A mechanical break in the insulation or a broken wire as a result of a poorly planned attempt to prune or fell the tree could cause dangerous step and touch potentials over a wide region around the work site.
And, just in case the responsibility is not clear, any action in response to the leaning tree should be coordinated by POCO.
I missed the tree wire note. I didn't know that's what they call it.
It's bad enough when a pigeon sh1ts on you!
Not to put too fine a point on it, the word "electrocute" means that it caused death. Your dog was merely shocked.I electrocuted my dog. . . but he was fine a day or so later.
From WikipediaNot to put too fine a point on it, the word "electrocute" means that it caused death. Your dog was merely shocked.
Formally, the words electrocute and electrocution always imply fatality. Informally, however, these terms are rather often used to refer to serious but nonfatal electric shocks.
