Designer371141
I have always used 75 degree C ampacity ratings when performing de-rating, regardless of the wire type because typical lugs are all 75c rated and seldom 90c. Everywhere I have worked uses the same theory to error on the side of the more stringent criteria. I recently was requested and told that when it comes to derating of wire due to conduit fill that you always use the 90c so you get higher ampacity ratings. IS this right, I have never heard of it, every example I have seen in the code as well as Ugly's uses Article 310 tables and 75c rated ampacities.
What is the industry standard, or if not what is a good rule of thumb, I should think the more stringent is the safest way to go
