tahir mehmood
- qatar
Hi all;
If i have a conductor of 55 amps, the terminal lugs at both side are rated at 60 centigrade, and the insulation is THHN. shall i select the conductor from 90 centigrade column or 60 Centigrade column. kindly clarify as THHN insulation comes under 90 column, and the rule says if amperes are less than or equal to 100 A, use 60 centigrade column.
