I was currently working in a store where I had to install two switches to control 6 existing lighting contactors One switch controlled five the other switch controlled one. Where my contactors where mounted had a existing nipple to the panel. I sent my neutral directly from the panel to the contactor. And I installed a 12-2 mc to switches around 50ft from the box. When everything was wired and I turned the switches on with the switch on I was getting 120 volts to the coil. However with the switch off I was getting 24 volts which was pulling the contactors in. After realizing the problem I pulled neutrals to my switch box then to my contactors. Even with the wires disconnected from the switch I was still getting 24 volts. After pulling my neutrals to the switch box and then to the contactor the problem was resolved. Can anyone explain the theory of this to me I would greatly appericate it. Thanks
