Dead Front Definition Abuse
infinity
New Jersey
Journeyman Electrician (retired)
I've been having a discussion with someone about the use of the NEC term dead front. Seems like almost everyone thinks that a panel cover is the dead front yet the definition in Article 100 doesn't really support that it actually describing a metal cover. I've heard others say that it's the inner portion of a cover on commercial style panels where there are two separate sections. That doesn't meet the definition either because you can still stick your hand in the panel and access the energized parts. IMO the "dead front" is not a physical piece of anything as it is a condition created by the use of a panel cover. Opinions?
The Article 100 definition:
Dead Front.
Without live parts exposed to a person on the operating side of the equipment.
I remember working on original 1930's open switchboards in Rockefeller Center where they had begun to replace them in the 80's. Scary stuff.
I agree with this and I like Wayne's explanation. Can anyone give an example of a "live front" condition?
go back 100 plus years where exposed equipment was more common and they maybe didn't call it live front but at some point when they started enclosing things more the term dead front became a thing.
Maybe can even go back to where there may been a cabinet door but opening it to access switches or overcurrent devices still resulted in exposure to live components. Today there isn't really that much that you open a door for rather routine tasks and are exposed to live components without having to remove an additional cover. Some safety switches yes. Most anymore won't open without turning them off or bypassing the latching feature, if equipped with such a bypass.
Open components are still common on medium and high voltage equipment but protection is usually via elevation and/or limited access to only qualified persons.
