Castor Troy
- Gardnerville
- Maintenance Electrician
I'm new to a company in Nevada. Prior to my arrival last week, there was a power outage with a tripped breaker 175 amp (sub panel) and it also tripped the main 3k amp. It appears that the contactor went phase to phase to phase. A-B-C I have no drawings or schematics; it appears this cabinet was hand made and piecemealed together. I'm tracing the primary and secondary wires from the contactor. With an Ohm meter I'm reading a "short" between A phase and C phase on the primary and A phase and B phase on the secondary. But I may be reading across two separate transformers. I realize this is scattered information but has anyone come across this type of scenario before? Advice? I removed the contactor to take it out of play; I still have the same readings on the wire.
