I went to a residence where one issue was a string of LED recessed lights either flickering or not working at all(I think primarily the latter).
Checked the switch, good. Found the 120V switch leg and individual drivers(small pucks) for each light(3 total on switch) in a box in the attic.
Everything was working properly but it appears the LED's themselves have all gone bad. Each power supply is still providing proper low voltage to each light unit.
I am scratching my head as to what might have caused all three lights to fail, particularly having each their own power supply. There is another string on a separate switch in the same bathroom working fine.
Could a short or surge on that switch leg have caused an over voltage and toasted the lights? And not damaged the power supply?
I tested with a known functional light and it works as it should. So I went ahead and ordered three new lights to match but am a little puzzled.
