Decision Tree for sizing circuit breakers
PhilLanghorst
St. Louis
Does anyone have a decision tree for sizing a circuit breaker based on the NEC rules?
Graphical decision trees would make the code easier to understand but I have never found one for any part of the code.
iceworm
Curmudgeon still using printed IEEE Color Books
North of the 65 parallel
EE (Field - as little design as possible)
This is the one I m currently using.
(Completed bad humor - moving on)
I'm not much help. Best I can suggest is to start with:
240.3, Table 240.3
240.4, A - G
310.15
Part 240, Part VIII Supervised Industrial Installations
Part IX, Overcurrent Protection over 1000 Volts, Nominal
An likely a dozen others I forgot.
There are about 100 bunny trails - unless there are 500. Follow each one to the end.
Suggestion:
Instead of looking for an all inclusive decision tree (which could look about like my attachment) consider making up a tree for one topic, say select an Overcurrent Device for a motor.
That one is complicated enough.
the worm
  • CB 1.pdf
sameguy
New York
Master Elec./JW retired
240.3, Table 240.3
240.4, A - G
310.15
Suggestion:
the worm
So I followed the light blue line and I think you came up with a wrong conclusion, could you look over your work and get back with a corrected version?
