Reading in 680.
Deck box with or without 120v transformer has a minimum horizontal spacing of 4 ft.
Correct ?
Pool guy says it has to be 10 feet. And the reason it can be closer is if it where " under "
The diving board.
Please confirm. Thank you
Also. Rather than another post and I'm sure it's probably even talked about before.
But perimeter bond. Below subgrade ? What if final grade was going to be a cinder block or pavers ?
Reason I ask is I believe the grade on this install is dirt and grass.
What's the subgrade depth for perimeter bonding ?
Thanks again.
Correct ?
The diving board.
Thanks again.
