staticcontrol
Hello Everyone,
A customer has purchased 4 special toilet seats that require it's own dedicated circuit and gfi protected. It draws 11 amps each. It does something with water ....etc.
Anyway, 3 bathrooms are on the second floor and one on the 1st floor. Full open basement where panel is. I can drill up through 1st floor to do 1st bathroom. I found a closet that I can snake walls through to get the 3 remaining home runs to the attic and then drop them down through wall to the other 3 bathrooms on 2nd floor.
How should I bill this.... time and material or by the dedicated circuit? Medium size house. Doesn't look hard to snake through walls with a hand hole or two in the closet. What would you charge.ball park?
Thank you.
Sincerely,
Static
Thank you.
Sincerely,
Static
