richwaskowitz
- Shelby Twp. MI, near Detroit
In regards to complying with Indoor Dedicated Electrical Space - I need to upgrade a residential service from 100 to 200 amps and am concerned about the location of the current panel, which will become the location for the new panel also. The panel is mounted to an outside wall and there is a 4 inch cast iron waste pipe running horizontally along the wall which passes directly under the panel. It seems pretty clear to me that this would not pass the requirements of 110.26 F (I)(a). There is a lot of other stuff on the wall to the left and right and a clear, alternate location is not to be had; not without considerable cost. If that piping is indeed a problem, could a work-around this requirement solve the problem, like building a frame on which to mount the panel to bring it, say 5 inches out from the wall so that the piping is in effect behind the plane on which the panel would be mounted?
