chevyx92
- VA BCH, VA
Can other general purpose loads be fed out of a server room panel? Panel is shunt tripped. I don't see anything that prevent me from doing it but just want to double check with you guys.
Assuming it is a room built under article 645. Yes. see 645.6Can other general purpose loads be fed out of a server room panel? Panel is shunt tripped. I don't see anything that prevent me from doing it but just want to double check with you guys.
I don't see 645.6 affecting the use of panelboard for other stuff. It needs to follow the code.Assuming it is a room built under article 645. Yes. see 645.6
Funny enough, my guess was that the panelboard and server room were not per 645, so it is just a regular panelboard. I have not needed the leniencies provided by 645 in many years.
