- Lockport, IL
- Semi-Retired Electrical Engineer
A small panel has two breakers that supply a transformer and a UPS. Their output goes to a ?UPS bypass switch? that is set up as ?make before break.? That switch feeds a branch circuit panel. I want to replace the transformer. I don?t think opening the transformer?s supply breaker is enough. I think the bypass switch has to be kept in the ?UPS? position, to prevent feeding UPS output voltage to the transformer?s location. But its handle is not lockable. Can this replacement be performed safely?
