- Lockport, IL
- Semi-Retired Electrical Engineer
I wanted to gather opinions on this issue, before posting anything in the “Proposals for the Next Cycle” forum.
NECA and ECM are continuing the very good work started by Charlie Trout (may he rest in peace) in publishing a daily code question and response. I started to compose an email to contest today’s response. But I looked at the NEC itself first. It turns out that the response correctly described the NEC language, although I had not expected that to be the language in the code. Charlie’s Rule saved me from embarrassing myself. Here is the issue:
The article 100 definition of “Voltage to Ground” provides a separate meaning for grounded and ungrounded systems. For the ungrounded systems, the definition of “Voltage to Ground” is “the greatest voltage between the given conductor and any other conductor of the circuit.” I think this is wrong. I think that the voltage between any point in an ungrounded system to planet Earth can be any value whatsoever. It’s not limited to the system’s line-to-line value. I would prefer that the phrase “Voltage to Ground” be left undefined, with no more than a brief mention that that voltage value is not constrained to be any specific value.
Am I misinterpreting the intent of this definition?
