I need a definition for the word riser.
Spec u/g section says to transition from underground to above slab with Rigid Steel.
Underground to be Rigid Non metallic Conduit
Underground bends to be rigid steel
Risers to be rigid steel
I have ran RNC between my 90 elbow and grade for final height adjustments and rigid steel above grade, owner says i can't transition from grc to pvc to grc
and is quoting " all risers to be rigid steel"
Risers are above grade, correct
