In the 2005 NEC page 70-96 250.24(A)(3)....I look in the definition section on what the code means of the phrase "dual fed service" ...what I have here is a back up generator and service feeder from my local utility would these be considered as dual feed to my system....??? if not then I pose this question ....this back up generator the neutrals are not part of the transfer switch so it is not a separately derived system....my question is at the service I have a cold water and ufer ground and at the generator I have a ground rod and ufer ground can i connect these grounds to common point??? like my equipment ground at the generator .If so where is this in the 2005 code...... thank you
