- Windsor, CO NEC: 2017
- Service Manager
1.) NEC Section/Paragraph: Article 100
2.) Proposal Recommends: [new text]
3.) Proposal: Add the following definitions to article 100:
Secured. Fastened to a structure or framing member by an approved means.
Supported. Resting either in a hole in a framing member or on top of a framing member, using only gravity to maintain the location of the installation.
4.) Substantiation: The cable articles of chapter three of the 2005 NEC use the two terms interchangeably, where they are generally interpreted to describe two distinct principles of installation.
As currently worded, the articles imply that the weight of a cable resting on a structural member is not supported unless it involves a fastening means (see 334.30, 332.30, 320.30). Given the reliable nature of gravity, it is generally accepted that cable supported by framing members will not float away or place undue stress at points at which it is fastened.
__________________________________________________
Am I a smartass or what?
When I started writing this, I took it for granted that the terms were used interchangably all over. In further research, I only found 320.30, 332.30, and 334.30 muddying things up.
I view supporting as using the existing structure to bear the weight of the installation. Without support, the weight of the installation would tear itself apart. In situations where the weight is borne onto the structure, securing it to the structure that's supporting it is silly. Gravity won't reverse itself, and if it did (
