mbrooke
Batteries Included
- United States
- Technician
Would this be the correct definition of ampere? I always assumed amps was quantity, or amount of electrons for a given period of time, or technically one columb per second.
Second in this question would A and D be the correct answer? This is for a 3 volt circuit with a flash light bulb, knife switch and DD battery.
Third;
Would changing the underline to "pass through them easily. " be more correct or is the definition still off?
4th, would B and C work as an answer?
Just wondering if I could make these better. Working on a teaching tool.
Ampere
The ampere (symbol: A) is the unit used to measure
current intensity.
Which of these could be used as a resistor in a circuit?
a. a pencil
b. a gas engine
c. a rubber eraser
d. an electric motor
Third;
Electrical insulators
Some materials do not allow electricity to pass through
them. These materials are known as electrical insulators.
Plastic, wood, glass and rubber are good electrical
insulators. That is why they are used to cover materials
that carry electricity.
10. Why is electrical wiring usually covered with a layer of plastic?
a-To make it look pretty
b-To help electricity flow along the wire
c-To make it safe
