In a post some where it was mentioned that cable coming out of the back of a meter pan for 200amp wire would violate the deflection of the wire to terminal (unless a conduit adapter... No thread... Is used)
It was suggested to come out of the bottom of the enclosure.
My possible issue is with 200 amp seu
Coming out of the bottom of the meter pan. 90 through the wall. Then 90 into the top of the panel may put the panel too low.
If I come into the panel from the back top might be better and give me the height I would rather have for the panel.
I've come in the back top of the panel before with no issues but I would like to make sure it is approved and not an inspector just not checking it.
Is it possible to enter the rear top of the panel and not violate this deflection code? (Or rear sides of the panel?)
How exactly and where do you measure from/to to check for the violation ??
Thank you.
Thank you.
