This year I've ran into two examples of where a delta connected service feed is feed into a single phase distribution panel. In the first panel I assumed that it was totaly in violation of the code since it had two separate breakers feeding the AC unit 3 phase. They had placed a two pole breaker in panel to feed two phases and mounted a single pole breaker to the side of panel to feed the high leg. (This I found in a water utility plant) I refused to replace the breaker since I did not think it was safe.
Yesterday I was called to a Post Office branch and found that the feed was delta and they had used a single phase panel, but here there was a three pole breaker with a common trip, one pole of the breaker had a side terminal where the high leg fed into. The breaker is clearly marked as a Bryant breaker, but I can find no record of Bryant ever making a breaker like this.
Is this in violation of code? I know that today I would use a three phase panel and identify high leg, but how to fix this easily without high cost of rewiring. High leg is only used for AC unit.
iss@charter.net
iss@charter.net
