emiller233
- pittsburgh, pa
- Controls-Automation engineer
We have a customer who wants to use a 600VAC to 480VAC transformer(50KVA), and i am not sure how to ground this things properly to meet UL508/CSA requirements.
I attached schematics that Eaton sent me for this transformer
this was Eatons response but I am not clear on what it is telling me:
There should be no ground connection on the line side. Since this is a delta-delta transformer there is no ground connection on the load side either. However the transformer is internally ground per NEC 450.10 and 250.4(B).
The customer does not want this transformer sitting on our main machine due to weight, so they want to put it on the floor right next to our machine and run a short multi-conductor cables(3 hot + 1 GND) to it and use 4-pin connectors on both the load side and the line side (to make shipping this thing easier). The breakers would be back in our main control cabinet.
How do I ground this transformer, if I even have to?
