- Simi Valley, CA
Straight 3 phase delta / delta transformer for x-ray equipment and A/C units. 208/480
1) Does it require a ground detctor as per 250.21 or is that only if it meets one of the conditions lised.
or
2) Do you have to corner ground the system?
3) If you corner ground the system, do you need to reidentify the equipment grounding conductor as a grounded conductor?
4) Can the grounded phase be fuse protected?
or
