mshields
- Boston, MA
A colleague came accross a delta delta 13.8 to 480 transformer; happens to be a 2500KVA, VPI type from the 60's. Will want to switch this out for new project if only based on it's age but would also like to add problems associated with this configuration. Haven't seen one of these in some time. Don't remember all of the issues associated with them. Seems to me there is typically a problem with voltage regulation and then there is the question of what happens when there is a ground fault on the secondary side.
In any event, you're thought would be greatly appreciated.
Thanks,
Mike
Thanks,
Mike
