Stevenfyeager
- United States, Indiana
- electrical contractor
According to my diagram, voltage across any two phases is 240 volts in a delta 208 high leg panel.....is this correct ? ( From one who doesn't do much commercial work) I need some more spaces and am going to add a 120/240 v subpanel. In the past, I've added a subpanel using I believe phase A and C to get a 120/240 v subpanel. But may I use Phase B (high leg) with A or C for this ? Since every 3rd space (high leg) is empty in this panel, this would require me to only remove one circuit and move it to the subpanel as opposed to removing two circuits. Is this correct ? Thank you !
