dm9289
Industrial Maintenance Electrician
- Pennsylvania
- Industrial process repair/ maintenance Electrician
In my work area we have incoming transformer with 480-277Y 4000 amp output.
We have many transformers before our motor control cabinets labeled Delta to Wye although our source is Wye, and measures as such.
We had a situation with equipment that we needed a 3 phase 480/277 Y to a 240/120Y.
When the transformer arrived it was marked Delta to Wye so I called the manufacture and they said just hook it up it will work and it did.
I obviously do not understand this help?
Is you using delta/ Wye as Wye/Wye common?
