You don't. A delta primary should be connected like a 3ph motor: just three lines and an EGC.On a delta to Wye Transformer using 208 as primary and 277480 secondary. Where do you land the primary Xos or H ?
Where does primary land X or HYou don't. A delta primary should be connected like a 3ph motor: just three lines and an EGC.
the 480/277 H-0 is your secondary separately-derived neutral which needs a GEC connection.
For probably, 99% of general purpose transformers: X designates the low voltage terminals and H the high voltage ones, per ANSI standards.where does primary land on X or H
As Jim said, H-x's are the high-voltage terminals in almost every transformer.Where does primary land X or H
