LR1688
New member
- South Africa
Hello
I'm an engineering student at a South-African university. I'm working on a high temperature oven project. The oven has three graphite heating elements. Each with a resistance of about 1 ohm. To power these elements I have a 18 kVA delta-wye transformer. Primary side = 380V, secondary side phase to neutral voltage is 100V.
I connect each of the three heating elements between phase and neutral on the secondary side. To control the power to each heating element I use a SCR with phase angle firing to limit the power. I can control the power input to the three heating elements independently of the other two elements. I will therefore be able to create scenarios where the load is extremely unbalanced. For instance two phases on full power and one phase turned off.
I understand it is good practice to ground the neutral of the transformer on the secondary side. What is the reason(s) for this?
How should I do this grounding?
I hope the questions if formulated clearly, please let me know if I can clarify anything.
