carl.arnsdorff
I am using a 24 kVA 480/240 VAC Delta-Wye transformer in a piece of equipment. I have a 65 A 3 pole breaker on the primary. The 65A breaker is routed inside the equipment to terminal blocks where line power is connected.
The secondary goes into a 4 pole 32 amp breaker where it goes into distribution blocks to the smaller single pole breakers to feed switching power supply loads, computers and other similar equipment.
I am specifying a 480 VAC, 30 Amp supply from the panelboard. The wiring and transformer are internal to the equipment. I plan to use 10 gage wire for the Panel wiring before the primary.
The wire(s) from the breaker(s) to the primary/secondary are 150C wire supplied with the transformer.
Shouldn't the incoming power wire be sized according to the breaker on the distribution panel (30A)?
How do you size the neutral wire and how do you size the ground wire for all three - 1) the equipment ground 2)the electrode ground and 3) the transformer shield?
What size
What size
