ishium 80439
I had a customer ask me a question that I'm not sure I know the answer to. He is a commercial real estate agent and is looking at this building that is fed with 3PH 120/240V delta/wye. He has a potential client that wants to know if the existing service will accomodate refrigeration compressors (I didn't ask how many or what they were for). My response vacilated between "it depends on the actual equipment" and "if it is listed at 208V nominal than it should eat 240V 3PH".
I have very little (read next to zero) experience with this configuration. Can anyone advise me on the feasibility of newer epuipment running at this voltage?
As a side note why does it seem that most industrial areas built between the 50's and 70's (at least that's what it seems like from my limited foray) were fed with this configuration? Was/is there any advantage over a straight wye?
Thanks in advance for your input.
