goldstar
- New Jersey
- Electrical Contractor
Can someone please explain "demand rate metering" for commercial buildings ? (Charlie this may be something you can elaborate on).
This is my (very basic) understanding of how it works. Residential metering is billed on a total usage basis and a flat rate per killowatt hour. Commercial billing is done on a per killowatt hour at a rate based on the the highest peak demand usage the building uses at a given point during any day. (I believe that point is measured by the meter every 30 seconds or so.) If, at any point in time, the meter senses that a building requires a higher demand for power, the billing rate per killowatt hour changes to a (predetermined and incremental) higher rate and is used to bill at that rate for the entire billing cycle.
Thanks in advance,
Phil
Thanks in advance,
Phil
