tsryan89
- Syracuse, NY
I have a question about the proper bonding of a shelter that can be connected to various power sources. This Shelter is used in a deployable radar system and therefore can be configured to operate off not only facility power, but also generator power. The system has a 3 pole transfer switch located externally to the shelter that allows for two power inputs. The possible configurations of the system are:
Given this configuration and desire to maintain a bond in all configurations, what is the correct way to bond this system? Is removal of the bond at the facility and installation of a bond at the shelter correct? Is a dual bond approach acceptable if the neutral is breakered at the facility? Should a kit be created to "bond" the system when deployed (undesireable as they will no doubt forget to do this)? Any insight would be well appreciated.
Regards,
Travis Ryan
- Connected to Facility Power on Primary with Generator (DEG) on Secondary
- Connected to Facility Power on Primary with no Generator Connected
- Connected to Facility power on Primary and backup facility power on secondary
- Connected to Generator on Primary with no connection to secondary
- Connected to Generator on Primary and generator connected to secondary
Regards,
Travis Ryan
