Re: Derate bundling MC cable ?
Originally posted by physis:
I think this is a more important point.
What about type MC cable? Technically this is like conduit
No, it's not technically like like conduit. Although I've made the same misinterpretaion.
Ok, so I know it is cable, but you can run it in wallsand above ceilings in a commercial building. You have to comply with straps every so often. The cable has to have the ground wire on a box. Flex conduit, which is conduit has to have a ground over 6 ft. So how can it not be considered a conduit? Is it because you already have the full amount of wire in it and cannot add any more wire?
Also, let's say you bundle it with a tie every 23 inches then there is some seperation between ty-wraps. Would this allow yu to go further and not be considered for derating?
Not that we do work like this, we mostly run EMT exposed and MC in walls. But is looks like more and more type MC cable is used entirely in small commercial projects.
Thanks, the answers we are getting are ineresting and helpful !!
