I just failed an inspection because the inspector did not see the Amps on my label
here is the label ,
(Some context PV system needed to de-rate main breaker in order to comply with 120% rule. Load calc allow it )
The new main breaker has the amps , the panel label has the Amps of the old Breaker .It is necessary to write down on the label ........" we de-rate from ___ Amps to _____ Amps?
here is the label ,
