designer82
- Boston
If I have a 1200 Amp breaker protecting a cable. Should the base or derated ampacity of that cable be at least 1200 Amps?
For most installations in both cases it's required to be 1200 amps or larger.Should the base or derated ampacity of that cable be at least 1200 Amps?
One exception would be if there is an applicable tap rule.For most installations in both cases it's required to be 1200 amps or larger.
