Ivan Young
- Simpsonville, South Carolina
Gentlemen, I have a question about a situation on the job which the journeyman simply did not explain clearly to me, so just for my information I would like to get some help.
We are running three different 120v 20amp circuits in the same conduit, each circuit has its own neutral and all three share one ground. Each circuit feeds five 20 amp receptacles in one large room. The first room is 100ft from the panel, the second is 110ft, and the third is 120ft. Based on distance alone we are using #8 THHN wires.
My question is, should the neutrals be counted as cc wire? Just so I would know in the future, what if we had to adjust for temperature and say 10 cc wires in the conduit so now our 20 amp circuit in only good for say 10 amps, what needs to be done to keep the circuit at 16 amps, increase the size of the wires?
My other question has to do with two outdoor flood lights controlled by two 3 way switches. These are high-end lights so the home owner wants to add motion sensors to these lights or if this is not possible he would buy lights with the sensors attached to the lights. Each light has two bulbs and is at opposite ends of the house. The problem is he also wants to be able to control these lights with the 3 way switches as well as by the sensors. Can this be done, and how?
Any help would be greatly appreciated.
Thanks,
Ivan
Thanks,
Ivan
